Wanted KC FJ40 Late Model Gauge Cluster WTB (2 Viewers)
fj40ingkc
kansas ciry
Looking for a later model 1981+ fj40 gauge cluster with 6 digit odometer, if you have one, or upgraded yours, please let me know. thanks -max 8168204035
1981+ with the 6 digit odometer?
I don't have one, just wanting to clarify
Updated the request thanks :)
i have this UNICORN , it NEW and Never installed comes in Toyotas parts box
stored in CLIMATE controlled storage in my home
let me know
thanks
Thanks Matt, looking for MPH usa option. The part number I am showing for the gauge cluster would have been 83110-60152.
you may want to double check your needed part #
a 60152 iS A KPH cluster also , its a dedicated CANADA SPEC. ONLY COLD CLIMATE spec. unit too .........fyi
if my tech is solid and correct , then i suggest you be open to a pro dates range of MPH unit NOT a specific part # ,
cluster superscede back and forth in a unique and puzzleing way indeed
Below is the ONLY MPH cluster i have right now
i pulled it from a PERFECTLY Running rig tto simply imstall the new KPH one , my clients like all new parts , i verified it all works perfectly and stand behind all my products i offer the same way
let me know
thanks
Part 83100-60152 (METER ASSY, COMBINATION) was found on the following models:
MarketDate rangeModelFrames/OptionsFound in diagram
N. America03/1969-06/1980BJ40,FJ4*,5583-01: METER
Model Dates:Matching Models:Model Options:Links to diagrams:
02/1976-06/1980FJ40LV-KCJK CND, VAN 2F , VKC RB
06/1976-06/1980FJ45LP-KKCND , PIC , 2F 4F
This is a 83100-60072
USA mpg spec
Never had face plate removed period !
It’s all
Original
And in good working order
Matt, both of the clusters in your pics are 5 digit, the 81+ would be 6 digit
Paul
let me know
thanks
my 60072 is period correct for your year truck , ......fyi
spot on !
Matt, that gauge is not period correct for a 1981. It is specific to General countries and only goes through 06/80. It's part number 83100-60180. Just FYI.
i missed all his various request details , he added several later after my post , edit the original first few posts
what about my 83100-60072 ?
is my application information correct for him or no ?
his requested part # 83100-60152 , Mr.Eagle comes up a KK or CANADA Colt climate KPH unit ?
thanks for your input :)
@fj40ingkc Max, do you need the whole thing or just the odometer/speedometer? You may find parts to build what you need with some of the parts you have already?
This would be going in a 1984 fj40. I believe 81-84 are close enough with the 6 digit odometer but I may be incorrect
1981 to 1983 USA are all the same. 1984 were Canada only so would have KMs and not MPH...
No both of those numbers are wrong for a 1981. They both only go up to 06/1980. Agree with you though that 8311-60152 is Canada only.
thanks for the correct tech Mr. eagle
kindly matt
