Can't you get a fiberglass trans hump from SOR? I'm considering it as a means to cut down on header heat.
I'm in Houston, if you want to try and Mudship it near me I'll bring it to SAS.Good idea Steve. I had a friend send me one that was posted yesterday. Shipping may be a bear as it’s in AL.
If you haven't already ordered a gas tank - I would look at the OEM option. I recently bought one and it was only slightly more than the CCOT tank because of a free shipping promotion with the Toyota dealer I bought it from.
Tank Assembly Fuel - Toyota 77100-60042 | Norwalk Toyota Parts
Tank Assembly Fuel 77100-60042parts.norwalktoyota.com
You should be able to clean up the splines with a small diamond or stone hone...Was trying to get the front axle wrapped and suspension finished while waiting for floor pans to arrive.
Need to pull this back apart and see why the axle is shy of the hub gear. Could be a race not seated properly maybe...
When to check the other side and couldn’t get the hub gear to fit in the axle.
End is buggered from separating the birf c-clip. Will need to source another outer shaft.. ☹
I had hoped to throw things together here. Had a friend drop into town for a few days that ate up time and then while he was visiting I sprained my ankle.Hey Dave
How’s the 40 coming along... are you SAS ready?
Bummer and awesome at the same time. You can’t beat time with friendsI had hoped to throw things together here. Had a friend drop into town for a few days that ate up time and then while he was visiting I sprained my ankle.
I had come to the conclusion before that I should invest the time in the 60 for the trip as it’s made it the last 2 years.
I’ll be going but it’ll be in the 60 for another year. More updates mid August!
Send it to the Haus of Klaus. Fly out and drive it to Ouray .From
To
Getting a little closer to getting moving on this again. @Kleatus please continue..
Looking back up at your picture Dave, that thing is awesome. I'm jealous mine wasn't that nice to start with. I hope you're glad I showed up with an empty trailer to "check it out" and twisted your arm... .
