I've had this problem since i got my car (HJ60) Thought i might try to get rid of it now, before i convert to turboism.
At low rpm 1000-1500 in high gears it's very hard to accelerate smoothly.. It "juggs" and "jerks" and wont pull cleanly.. I can work my way around it by stepping off the gas and slowly repressing it. I kinda have to carefully get it going
If i just leave my foot on the pedal the kangaroo-effect gets stronger and stronger
So when i slow down to f.ex pass a pedesterian, a horse or just slow down to below 60km/h for any reason, I'm forced to shift to third when i should be able to just coast along at 1000-1200 rpm in 4th (down to 45-50 km/h) and slowly gain the speed back
No smoke.
Someone told me he had the same problem and it was solved by changing all the hoses that go from the fuel-tank to the "diesel-vapour thingy" inside the "wall" next to the filler-hole. ( i call it the squid, cause it looks like one)
Any other ideas?
hmm.. what else can i add here....
The injectors are new.
The primer(hand)-pump will leak when pumped (when unsrewed)
It starts easily and otherwise runs just fine
What does the "squid" actually do?
Anyone else had this problem?
Easy fix? (yes please)
No smoke.
Any other ideas?
