Just shackles???
Discussion in '40- & 55-Series Tech' started by Shastapk, Mar 1, 2004.
  1. Shastapk
    Shastapk
    12
    Jan 29, 2004
    Have stock everything on my '82 FJ60- saggin a little bit in the rear. I would like to lift it 1-2". Can I just add bigger shackles and if so, are there any minuses. What about getting the greaseable pins and the newer type of bushings also? Thanks again guys!!!!!
  2. dylan
    dylan
    246
    Dec 23, 2002
    it may throw your pinion angle off a bit (may get a vibration). you can cure it with a pair of spring shims.
  3. bad_religion_au
    bad_religion_au
    2,213
    2
    Apr 24, 2003
    you can extend your shackles by 2 inches, which will net about 1 inch lift, as 2 inch of shackle sort of ='s 1 of lift, but i wouldn't go higher than an increase in 2 inches of shackle length but as explained above, it will mess with your pinion angle.
  4. 89GASHOG
    89GASHOG
    3,491
    551
    Oct 22, 2003
    The Last Frontier
    I replaced my rear shackles for the opposite reason. When I bought my rig, it had poor quality, flimsy looking 3" lift shackles. Got the extreme shackles from SOR, with new bushings, shocks and sway bar bushings. I'm very pleased with the ride, and FWIW, no symptoms of pinion angle problems before or after. I think it's the way to go. Or you could spend 1K on the OME lift and possibly end up with the cruiser sitting high on one side.
