Just Purchased a 1993 with 220K.
Discussion in '80-Series Tech' started by fisherman978, Mar 13, 2018.
  1. fisherman978
    fisherman978
    255
    117
    Feb 4, 2018
    Boston
    Hello all
    Just purchased a 1993 80 . got a good deal on in. not so rusty but at the moment it needs a fan clutch and a new alternator and belts. what else should i change along with this. the previous owner took the belts off and used the fan clutch in his other 80 series so all the pulleys are kind of seized up. what else should i purchase along with the alternator , and fan clutch, ..... new fan blade? water pump? just trying to buy it all and get in there once. any help is greatly appreciated. theres rust starting on the outside of the top tailgate ill need to address asap the front two leather seats are ripped beyond belief . i need a Clock as the clock has been punched or busted out and a few other interior switches. have not seen the truck drive but it did start fine with a little smoking but it had been sitting for a year.
    mreedbmwm3, Warpigg and Fj81 like this.
  2. Malleus
    Malleus
    2,250
    Media:
    30
    Albums:
    5
    1,286
    Jan 5, 2017
    Charlotte, North Carolina
    Groovy wheels...did it come with the boat?
    fisherman978 likes this.
  3. Hedgehopper88
    Hedgehopper88
    19
    24
    Mar 1, 2018
    Swifton AR
    I'm really digging the color combination for some reason.
    Warpigg likes this.
  4. gummycarbs
    gummycarbs
    1,025
    786
    Apr 14, 2016
    Oregon
    Why would you need new fan blades? The water pumps very rarely fail.
    I'm a fan of replacing starters and alternators right off the bat. The power steering pump is probably leaking or will fairly soon, and it's easy to get to it with the alternator out (Gates PS pump rebuild kit is ~$15 at Rockauto). Plan to replace at least the PHH (search if you don't know what that means) and flush the entire cooling system thoroughly.
  5. decoco
    decoco
    1,209
    Media:
    1
    Albums:
    1
    409
    Oct 5, 2015
    Canada?
    I’m a little confused, you’re in Boston?
    Is this a diesel? If not what engine is in it a 3fe a 1fz, just never seen this color combo stock Edit other than in non na markets. Are the seats cloth or leather ?
  6. decoco
    decoco
    1,209
    Media:
    1
    Albums:
    1
    409
    Oct 5, 2015
    Canada?
    Regardless looks like a great deal.
  7. Red Merle
    Red Merle
    2,364
    1,525
    Jul 7, 2016
    Twin Ports of Superior, WI and Duluth, MN
    I have always thought that color combo was awesome! Most of the ones I have seen were from overseas though and I thought they were '91-'92 models. TIL...
    As for the belts, you could do the water pump, but most people think they are good for at least 300K. The belts should for be Toyota belts though. Fan clutch might be worth looking at, but you live in Boston, so it might not get hot enough to run into cooling issues.
    As far as the rest of it goes, there is no end to the PM that you could do, but one thing at a time isn't the worst way to go about it. How do the knuckles look?
    decoco likes this.
  8. whaler
    whaler
    110
    36
    Aug 16, 2017
    NYC / CT
    Nice snag. I would do water pump too. See if your idlers and AC Pulley are good. Fan might be ok, just check it. Cool Rig
  9. BILT4ME
    BILT4ME
    5,349
    Media:
    3
    Albums:
    2
    6,308
    Nov 9, 2012
    Olathe, KS, USA
    Looks like it has lockouts on the front hubs too...........
  10. brian
    brian SILVER Star
    8,882
    2,348
    Feb 7, 2003
    lebanon,pa
    the color was available in 93.
    fisherman978 and decoco like this.
  11. decoco
    decoco
    1,209
    Media:
    1
    Albums:
    1
    409
    Oct 5, 2015
    Canada?
    Only in 93? I did not know this
  12. ppc
    ppc M Go Blue
    2,094
    628
    Aug 18, 2003
    Nashville, TN
    Thermostat, all heater hoses including smaller bypass hoses and heater control valve.
  13. fisherman978
    fisherman978
    255
    117
    Feb 4, 2018
    Boston
    The thing is the guy i bought it from he bought this as a parts truck for his wheeling rig. the only part he took off was the fan clutch. he installed a different model fan clutch thats not fit properly now so i will 100% need to replace it. i figured why not the blade also if i was in there. as for the alternator its not moving and all the other belt driven pieces are all seized to i believe as he had the belts off for one year. as for rust theres really not anything bad considering in north of Boston. just a little on the rear hatch that i think i can repair if done in the next few months. The interior is Leather, second and third row are in great shape front seats have had it. im missing a few interior pieces i will post more photos tomorrow we just got 12 inches of snow..... it has the sunroof , i don't think it has lockers . For $2k i was happy to take it off his hands. i was not in the market for a 80 yet although ive always wanted one until i found this one. has older Edelbrock Shocks and Springs that will need changing but first thing is get it running.. please if theres anything else i should pickup to do at this time of all these other parts any input would be greatly appreciated ill post more photos in the morning. just had it towed home last night, detailed the interior, then we got hit with a storm up here..
    so far before i make my order at rock auto this is what i have
    Ideler Pulley GATES 36788
    Fan/Alt Belt ACDELCO 15447M
    ASIN Fan Clutch AISIN FCT004
    ASIN fan blade AISIN FNT004
    ASIN water PUMP AISIN WPT023
    Denso Alternator DENSO 2100181
    Spark plug wire set DENSO 6716172
    Spark plugs DENSO 4503
    Timing Set ??? ITM ENGINE COMPONENTS
  14. fisherman978
    fisherman978
    255
    117
    Feb 4, 2018
    Boston
    Thanks!! definitely think it needs the Idelers and AC pulley, did i get the correct ones in my list?
  15. fisherman978
    fisherman978
    255
    117
    Feb 4, 2018
    Boston
    Whats the best wa
    whats the best way to examine the knuckles?
  16. fisherman978
    fisherman978
    255
    117
    Feb 4, 2018
    Boston
    Pictures to follow in the morning
  17. gnarlytoes
    gnarlytoes SILVER Star
    344
    Media:
    5
    Albums:
    1
    205
    Nov 11, 2010
    Beech Bluff, Tennessee
    If you are going to put in a new timing set, go ahead and get a new oil pump and power steering pump while you're at it since you will already have the front pulley off.
  18. slow95z
    slow95z Always parting 80s GOLD Star
    1,955
    Media:
    1
    1,209
    Jul 27, 2008
    Dublin GA
    just buy 200 bucks worth of parts and fluids and do it. its cheap and i have never seen an 80 in my life (outside of mud members) that the owner took care of the front end. they are always worn out and need to be fixed.
  19. Alex Fogg
    Alex Fogg
    116
    Media:
    11
    Albums:
    1
    32
    Aug 10, 2015
    New Hampshire
    I'm in southern NH, let me know if you need help, I might be able to help, or point you in the right direction.
  20. decoco
    decoco
    1,209
    Media:
    1
    Albums:
    1
    409
    Oct 5, 2015
    Canada?
    the only thing I'd recommend is not buying from Rock Auto due to their abhorrent customer service, but some people need to learn the hard way, just like I did.
