iptman
You know I was going to link to the mustard 40 he just finished but that might be a little overwhelming!
Get it running, driving and stopping 1st. Change the fluids and make it safe. Then most importantly, drive it. You'll figure out what you want to do next. As mentioned b4, it's your vehicle, it's cool it's a family thing too. You'll find there are purist and folks who aren't, on this site. We all are Land Cruiser fans. The wealth of knowledge here is incredible. The folks here and the search function will be your friend. Youll likely start to turn a wrench or two. B4 you get into body work you should consider getting the mechanics in order 1st.
I know that Arizona does not have safety inspections but guessing the rust on the rear sill would not pass a safety inspection. The bumperettes and rear frame member are painted blue which means may have had possible rust repair once. Rear sill another color suggest rear sill repair a second time. This the many just the center and not the corners. The rear sill support is one piece. Not done right wheel wells and hard top are not supported correctly. I would access if it's structurally sound before driving it. Has to be a reason it's been parked in a garage for twenty years. I have a couple of old FJ40s in the backyard with rust rear sills. Not sure I'll ever do anything with them because of what it takes to repair a rear sill the right way.
I wouldn't repair the sill unless I did it right. Plus I wouldn't bother if it was possible to happen, in which case on the East Coast probably look into Poor Wally. While not original he is known for repairing rust to last as long as possible in the rust belt.
You were both right, as seen below. The back is much, much worse than I was aware.I think Living in the past, is correct. I appears at least the back end has been repainted, and some one did replace the rear sill sometime after the painting. It looks like they didn't replace the curved pieces of the sill that extends into the 1/4 panel, where the rust is bubbling. Get it safe and drive it.
Now I need to reevaluate the whole plan.
[QUOTE="Living in the Past, post: 13084617, member: 6492"
You say you do not have garage space for the folks FJ40. If left outside and then plan on driving on the beach would think long and hard before spending the money to restore it to only have rust showing up in a few years.
I did like the looks of
Weekend vehicle is really what the purpose of the truck is. I do like the trucks I have seen pictures of with the OME suspension, and figured the old suspension will be sagging at this point anyway. We go down to Southern Shores, NC probably 4 times a year and drive on the beach while we are there, so I want something that will be able to get us there and not get stuck on the beach. Beyond that, I have no real plans for serious trails.
I have little to no wrench turning capability, but wouldn't mind learning a few things. What would a very light restoration run?
