Hi all, my second post here.
I just purchased a 2000 LC with 233k Miles. The Tb/water pump were done around 165k. I wanted to do a few things right away so I was going to do the fluids
Oil change, front and rear diff fluid, transfer case fluid, grease the drive shafts, heater t's and the transmission fluid change. I think that should be good as of now. I had a question is it better to do a transmission flush or a complete drain then refill? Also the lower hose where the heater t connects looks like its leaking slightly should I replace the hoses as well or just needs a better connection where the clip connects?
Thanks all
Thanks all
