- Thread starter
- #21
You’ll need to pull the block drain and hopefully eventually get clear flow out that port.
Make a cover for that lower hose outlet that you can seal, then pour as much evaporust in from the thermostat hole till it’s full and let it do the work.
Sorry, do you mean pull the block from the frame or is there an actual block drain? I assume you don't mean the radiator drain. I'm guessing it's on the passenger side of the block
