Problem:
My alternator went bad last weekend. Not too big of a deal to swap it out, however, the tow truck driver used a jump pack to start it and drive it up on the flatbed and off when he got to the house. So, I swapped it out, charged the battery and cranked it up but, had no power anywhere inside the vehicle. Chased fuses and wiring and questioned my own work on whether I installed correctly. Pulled the new alternator and had it bench tested, it failed. I got a new one and had them test it before I left the store, installed it and still had no power. Then I started checking relays and more fuses. Finally, found the culprit. There is a 100amp and 140amp fuse on the positive lead for the battery. They were both blown. Swapped them out and everything is fine.
Lessons:
1. The fuses worked and did exactly what they were supposed to do, they blew out and saved the rest of the electrical system from getting fried.
2. Be very careful when using a jump pack on your vehicle, they can put too many amps in and wreck your day and night.
3. Stop by your local shop and have a spare for those fuses. The 100amp was available at auto stores locally but, the 140amp was only available online or at Toyota. (I have one of each on hand now).
Lessons:
