Jim & Tim here's one for ya! (DVD)
Discussion in '80-Series Tech' started by flintknapper, Aug 1, 2005.
  1. flintknapper
    flintknapper
    5,447
    2,189
    May 22, 2004
    Deep East Texas
    I noticed my windows and door locks had gotten a little "slow" of late....so I decided to pull the master control switch and clean the contacts. Did a search and came up with something IdahoDoug had posted awhile back, and tore into it.
    This is a very simple project and took all of 20 minutes to complete (including finding the little spring and plunger I blew out of it with the air hose). It may not be the cure for everyone...but it was for me.
    I found quite a bit of black "sooty" stuff on most of the contacts. I used contact cleaner and a soft brass brush from my dremel tool set to (manually) clean everything.
    The result was 1. Windows that operate about half again as fast they had been..and 2. A passenger side rear door that locks and unlocks every time.
    I also sprayed the window channels/weatherstrip with silicon spray and cleaned the dirt line that develops on the window glass right at the top. This didn't seem to make any difference...but I like things right. Cleaning the contacts is what did the job.
    Its pretty straight forward and once you get the panel open you'll see how it all works. There are a few small parts to keep track of.....but nothing that should scare you off.
    It would make a good project to go on DVD along with some others.
  2. reffug
    reffug
    3,925
    11
    May 28, 2004
    'in dat der briar patch'
    Well Flint, why didn't you videotape yourself doing it. :confused:
    And don't say its cause your not photogenic. :D
  3. 97 FZJ80
    97 FZJ80
    1,539
    Albums:
    1
    9
    Jun 3, 2003
    Plano Texas
    I have a digital camcorder (MiniDV) and a DVR. If someone wants to "help" me rebuild the switches, I'll be happy to make a DVD for distribution.
    John
  4. lx450landcruiser
    lx450landcruiser Moderator
    2,781
    10
    Sep 22, 2003
    Uganda
    sure ill help but ya got ta come to AZ
    mike
  5. tarbe
    tarbe
    1,494
    40
    Aug 6, 2004
    Houston, Texas for now - Romance, MO soon!
    Jim and I have both already done that fix to our trucks :) It is really worth the 20 minutes or so it takes!
    Doesn't strike me as the kind of job that needs a DVD. Are you just padding your post count, Flint? :grinpimp: :princess:
  6. flintknapper
    flintknapper
    5,447
    2,189
    May 22, 2004
    Deep East Texas
    Not trying to pad...really!
    There are little tips that could be passed along is all.
    All of the little "bird wing" rockers are the same size and shape....so you can just take them all out and let them soak in solvent. Its worth pointing out that the drivers window has an auto feature (which means that switch is different underneath), it has a small spring and plunger.
    Also, IF the spring in the rectangular window lock mechanism falls out (mine didn't) then it would be nice to know how it goes back in.
    It's all self evident if you're a detailed sort of person...but I can imagine someone pulling it apart too hard and having all of those tiny parts drop on the floor. Bet you could sell a DVD then!
    I didn't have any problem with it....(and I've been known to have trouble with plastic) , but if someone like my nephew were to attempt it .........
    Oh well, never mind.!
  7. elmariachi
    elmariachi
    1,977
    23
    Jan 4, 2005
    Shufflin' Through the Texas Sand
    My DVD recorder doesn't like assembling multiple segments...it likes one single DVD stream shot in one setting. And I'll be damned if I am going to spend any Cruiser time or dollars solving that issue.
  8. 97 FZJ80
    97 FZJ80
    1,539
    Albums:
    1
    9
    Jun 3, 2003
    Plano Texas
    My DVD recorder can assembly multiple segments just fine. I use the IEEE1394 (Firewire) port to download the video between the miniDV and the DVD recorder harddrive.
    John
