jig saw (wood work)
Utah
damn, i didn't know there were so many jig saws out there.
i've seen 3 different black'n'decker all under $40. then i do a search
online and find a $140 milwaukee.
any of you guys have anything inbetween?
i just need something decent to get through pine,
maybe the ocasional 3/4" mdf or ply.
or you think i should just stick with my dremel?
For occasional, less precise work, the cheap'o will likely do you! If you think of tools as something you keep forever (or a very long time), need something more precise and will get regular use, get a Bosch.
I have bosch with bosch blades, bought it years ago and whatever it cost, it was worth it.
But the el cheapo with good blades may be ok also.
any jig saw with the cheap blades will not be much fun.
Ditto. I have had a couple of the $35 (then) jig saws...didn't last and they didn't function all that well...but heh what should I expect! About 16-years ago I splurged and bought the Bosch. It has seen heavy use...and it works great and lasts and lasts and lasts. This was my first experience with a 'real' power tool and changed my mindset for all subsequent tool purchases.
By the way the new (intro'd a couple years ago) Bosch is even better since you do not need a tool for blade changes. Also if you are going to consider purchasing a 'real' tool...be sure to check out Festool also: Heavy duty + intelligent design + outstanding warranty/customer service.
All I can say is when you buy a real tool, save from losing it/getting it stolen, it will probably be the last of it's type you'll need to buy for a long, long time!
I have a 20 or so year old B&D that works...But I was a friends house and tried his bosch....I could not believe the difference. smooth quiet it just felt better. 'course my old B&D still works it just chatters and bounces through the work....New B&D are prolly nicer than my old cheapy as well....Not being a fan of disposable tools I would prolly try to pursue something above the cheapest one availabel....Depends alot on what you anticpate doing with it I suppose...
I have a Dewalt. I bought it 3 years ago. Used it a lot on a project I was working on. It probably got about 30 hrs of usage on it over 4-5 days. Since then, I've used it around 10 times to a total of maybe 50 hours. It has worked really well for me. It replaced a 20 yr old Craftsmen model that my Dad gave me that burned up. Overall, I'm pleased, it was $100 when I bought it.
I have a Porter Cable, which I use for boat building and general projects around the house. It is pretty good - cuts straight, easy to use, plenty of power.
However, I bought a Bosch barrel type (no top handle) for my sone in law, and it is the real deal. Amazingly easy to use, trackes and cuts well, and has planty of power. Highly reccommend that you ALWAYS buy the best tool possible, on the theory that, if you needed it once, you'll need it again.
M
Another vote for Bosch. I'm a carpenter and it's the only jig saw I'd use. In fact I bought one for use at home too.
Another vote for Bosch. It came with a free palm sander for same price as the jig saw alone. I had a Milwaukee (that got stolen) that was nice, probably had the easiest blade change I've ever seen, but the trigger wasn't variable speed -you had to turn the dial.
thanks for the info guys.
i'll definetly look into the bosch.
Bosch!
I own alot of Bosch products and definitely love them, but I rarely ever use a jug so I bought a 40 dollar Black and Decker that has plenty of power and is easy to manipulate
