JDM 3B BJ73 - Turboing worth it? (1 Viewer)
Coquitlam, BC
I have a 1988 JDM BJ73, so I think it has the 3BII. So from what I understand, I can't just flip my manifold because it might pop through the hood and I can't use a 13BT manifold because it won't fit.
I have no skills in welding whatsoever to fab my own manifold... Do you think I have a chance or should I just leave it as is?
cruiser_guy
Good morning from here, Just finished updating ou
Wherever the truck stops!!
Website
wirrell.com
A turbo is worth it but in your case it won't be easy. I have a rotary pump 3B (maybe a 3BII but I don't know). I have a 13B-T manifold and I'll know if it works in 2-3 weeks when I get back to Guatemala where my FJ45LV 3B project is.
Coquitlam, BC
I think the FJ45 has more room underneath the hood compared to a BJ73 doesn't it?
From the threads about turbo 3b, the pictures showed quite a bit of room underneath.. the BJ is slightly more cramped inside
Tapage
Club 4X4 Panamá
Panamá
Website
www.4x4panama.com
Yap .. hou have enough room under the hood ( FJ45 ) to allow a 6 bangger with not to allow 4BT or 3B-T
brownbear
Mod in Hibernation
Moderator
North West Ontario
Use this..................v
https://forum.ih8mud.com/showthread.php?t=133833&highlight=3bII+turbo
Call an importing company for parts, such as GandScruiser parts, or Japan4x4, or Mot....etc... They should be able to track one of these bad boys for you.
Also Crushers made an adapter for the 13b-t manifold to the 3bII. He might have more to sell.
Coquitlam, BC
interesting!
I'll look into maybe ordering one of those.
As I just performed my first oil change, do you think there's a lot of skill involved in turboing? Skills that exceed my level?
I tend to be a bit clumsy with tools :(
brownbear
Mod in Hibernation
Moderator
North West Ontario
interesting!
Depends.....
I think most people can handle these kinds of jobs. But, how fast do you need your truck driveable again?
If it takes a week so figuring it all out, and you have a second car, why not? I would give it a try.
Also depends where you live, you might find a great shop willing to give it a go for you for not too much $$. But the idea if a junkyard turbo is DIY.
Coquitlam, BC
Depends.....
Yeah, I have a second car. I'm just always afraid to break something during the install and something going catastrophically wrong.
Coquitlam, BC
1988 could be 3bII or not. You need to check before you do much planning. If it is a 3BII. The manifold in this thread and brownbear's adapter would get you cooking.
The only way that I know it is a 3BII, is that it has a rotary pump. On the metal plate underneath the hood, it says 3B. not sure if they would say 3BII if it was though
lowenbrau
Rockyview County AB
Pretty much all JDM 3Bs got the rotary pump. It's not a good indicator.
brownbear
Mod in Hibernation
Moderator
North West Ontario
Look at the pattern on the exhaust manifold and compare that to the thread I mentioned above. You can see the difference in the manifolds.
Coquitlam, BC
I checked the exhaust manifold, I think it looks more like the 13BT manifold. It doesn't have the extra triangle notch that goes in at the end. Though i couldn't see clearly, there was a metal plate in the way, i had to feel inside for the extra bit.
I cant remember if the 3BII is cast into the block or not. The 3B is cast below the intake manifold, above the edic
I also found 3B cast into the side of the block below the intake manifold.
So I have a 3B and not a 3BII? :doh:
Looking at it again, there seems to be a lot of stuff in the way, like the throttle cables and a reservoir of some sort bolted to the back which might get in the way, I dunno how big the turbo will be though
brownbear
Mod in Hibernation
Moderator
North West Ontario
So where do you live?
Crushers here has turbo'd a few JDMs on here, so you might be able to buy him a slice of pizza and get his info on it...If you live in Calgary.
But others may be able to chime in.
Coquitlam, BC
I live in BC in the greater vancouver area.
