Jass seat lowering adapters
Glad to hear this and this is likely my next todo for sure!
Maybe @sdnative and I can get a 2 person group discount 😂
I would possibly be interested in a set depending on pricing.
I also have a set of seat jackers for sale :)
Hey guys,
I finally got around to installing the Jass Seat Lowering Brackets, and I'm very happy with the results. Before installing them, I had the seat jackers on the front, and here are the measurements I took of the drivers seat all the way back and in the lowest position:
- front of seat to ceiling: 31-1/4" of height
- rear of seat to ceiling: 38" of height
After installing the lowering brackets and removing the seat jackers:
- front of seat to ceiling: 32-1/4" of height
- rear of seat to ceiling: 38-3/4" of height
I never really liked the additional seat height after I installed the seat jackers and now with both removed, the seating position is much better for me. I always felt like I was sitting way higher than any of my other vehicles in the LX...now it feels as it should. Post install, I've electronically raised the front of the seat a tad, and it feels so much better. Plus, getting in and out of the vehicle while it's running is much easier to slide my legs under the steering wheel with everything in the stored driving position.
Install was easy...followed their supplied instructions and everything went exactly how they described. I did use blue threadlocker on the bolts/nuts they provided to secure the new brackets to the slider rails. Lastly, because it does lower it so much in the rear, I used the angle grinder to take about 1/2" of the outer plastic trim of the seat just in the very back corners closest to the b-piller, because when the seat was all the way back it was causing the outer trim of the seat to bow out from hitting my carpet/husky liners. I also had to trim the husky liners so it didn't interfere, as well.
Otherwise, simple straightforward install, and I'd highly recommend them to anyone that thinks the seating position just feels too high, whether you're tall or not. It now feels much more normal and comfortable to me.
If anyone's wanting some seat jackers, I'll sell my set for $100 shipped. :)
Chris
Thanks, Chris—spot on with details and install notes. Good call on the rear trim tweak; it can rub enough for squeaks in the rearmost position, I will add this detail to the manual as well.
I am in for a group buy if you think it makes sense - it would be aiming to reduce shipping/tariffs. $40/set is the idea if there's interest, otherwise I can think of some discount code incoming for a limited time.
I will most likely be interested in the driver's side (left side)
BTW you have an extra zero on the website. 2000 series vs 200 series.
Id be very interested around that price point. Are there still tariffs being applied?
I’m in for a drivers (US Spec) side
After spending this week driving it more, I’m beyond happy with the results. It’s honestly the thing I hated most about the vehicle. It’s as it should have been from the factory now, in my opinion.
Chris
I am quite enjoying the experience as well, Chris. I also upgraded to stiffer anti rollbars as its my daily most of the time and I am used to certain speed in the corners with the Miata I am trying to match with the truck:).
As for the GB - I am unfortunatelly unable to take care and organize it. It would be best of you could arrange someone to receive them and them forward them locally as to save on the shipping and tariffs additionally.
I sent you a pm
I am interested in a set if a GB can be arranged
@ravencr which is the correct set for US DRIVERS side?
Left or right? Which did you order? I only need drivers side
Thanks
Hello guys, I am sorry for missing for a while here. It does not seem as there is a tall boys majority here and a GB will be unlikely. Please contact me best through the shop (as I would respond immediately) for a single order discount code in this case. I should be checking the messages here too but not that frequently. Thanks!
Chris
Do you have pics of the install process?
