- Location
- United States
MANY Detailed and notable Modern Factory Design Improvements in both corrosion resistance and electrical conductivity too ..
: Sealed O-Ring Connector Plugs water proof as they get ..
: : Longer Plug Tail Leeds excused in water proof loom
: no more 5mm machine screw B/S mounting lamps to rear frame member section on chassis ,
NOW : affixed threaded studs to lamp base housing only need a hex nut , simple 5 STAR approach I will give Toyota here
- Rubber water proof lamp bases boots are tight and snug , top shelf here
- ALL 3 lamp sockets have a independent ground wire
affixed to them with a brass rivet and then coated in green anti rust coating
$364
set / pair / LH and RH lamps sold together .....
