Hi All,
I have two 12 ton Torin Jack Stands. I plan to remove my front axle to swap gears and do a locker. I had to do so for the rear to get the differential back in with the copper tubing. To hard laying under the rig.
I’m worried about the weight balance if I put the stands under the frame rails right before the front wheel wells due to the engine weight. I don’t want the rig to tip over on me! I do have a rear tire swing and bumper with a 37 creepy crawler on it. That is some counter weight.
I also thought about putting another 150 lbs of weight in the back of the rig as well.
Thoughts about putting jack stands under the frame right before the front wheel wells?
