Builds “It’s only an axle swap and a motor swap” aka AK2AL aka Dream Build (4 Viewers)
Alabama
Website
www.tachedoutoffroad.com
Well, it’s finally happening.
The Dream Pig showed up today!
After months of searching and a few false starts, the rust free, California edition, super clean, bad transmission, great deal, ‘73 Hog has landed here in Tuscaloosa today.
As it sits today:
1973 Toyota Land Cruiser FJ55 “Iron Pig”
Chebby 350, 700R4 (broken)
Twin stick Toyota t-case
Saginaw PS swap
Four wheel disc brakes
Vintage Air AC (possibly in-op?)
Pretty good window rubber all around
Bucket seats (power!!)
New carpet with sound deadening
Radio works
Dome light works
Gages seem to all work
Back window works
.....damn, what a beauty...
so, this is my
1) Dream Build of 20 years of driving Toyotas
2) retire from Army and drive from Alaska to Alabama summer of 2021 build
3) Shop Build to advertise my new business
4) “it’s only an axle swap and motor swap” build
Build specs:
:::UPDATED:::
-1973 FJ55 Land Cruiser “Iron Pig”
-2001 4.7L 2UZ out of a LX470
-NorthWestToys bellhousing
-Off Road Solutions wiring harness
-Marlin Crawler built R150F 5 speed manual transmission
-LC Engineering dual comp clutch
-Marlin Crawler adapter for gear driven case
-Marlin Crawler 23 spline dual transfer cases
-Redesigns triple stick/ rear case relocation
-Front Range Off Road low profile skid plate
-FROR Tcase rear mount
-Flex a lite Black Magic 3300fpm fan. 190-205* in traffic with A/C on
-1994 frame/ E-locked FJ80 axles
-Fully serviced axles/brakes
-RCV chromolly front shafts
-Imported locking hubs
-Slee heavy duty tie rod and drag link
-Slee heavy duty radius arms
-Old Man Emu coil springs
-OME BP-51 giant shocks (bypass)
-cold Vintage Air A/C
-55 gallon fuel tank
-Holley in-tank fuel pump and Holley mat fuel pickup
-ScanGage engine monitor
-17” steel wheels (x5)
-35” KM3s (x5)
-1/4” steel bumpers
-9.5k winch
-Underbody and inside painted with three layers of rust prevention and heat/sound proofing
-two layers of dynamat stuff (not stuck down)
-electric bucket seats, power lumbar, arm rests
-Tuffy center console
-Bluetooth radio
-x2 6x9”s and x2 6.5”s
-front and rear off road lights
-spare drive shafts, bearings, hub, fuel pump
-gets 15mpgs cruising at 80mph. Will go 100mph with one hand on the steering wheel
-400+ man hours to build this Pig
.....last but not least, in a steak dinner bet made with @cruiserjunktion , this will be ready by the SSS 2020!! Yes, this fall..
special thanks to @cruiserjunktion @J Mack @FJ60Cam @nvrlose54 for their motivational spirits to help promote me to spend money I don’t have!!! Yall are the best fellas!!
Bacon pics!!!
——>>build actually starts on p.9 <—-
Oh, this is gonna be good. I am talking with Jason on his brackets too. What OME springs you going with up front? Stock height, medium, heavy or Js? I'll be sub'd to this one for sure.
not sure. I have some stock, OME 2.5” and Js here at the shop.
think the mediums will be just right for the weight. Add a spacer if needed. 3-4” lift to clear 35”s I think.
I have gone through a few trucks looking for the perfect base to start with, and this is it. Tons of parts here already, more paid for and just waiting to show up.
Duuuude awesome build plan. So I have a set of Chevy seats that I was gonna put in mine too. Anyway to get some pix of how yours are mounted?
I’ll get them today.
In theory, I like a bench seat in an old truck, but after 20mins (or 3 days) of driving, adjustable buckets with arm rest are going to be nice honestly.
This is going to be a road trip machine and not garage queen. The seats, suspension, motor, huge gas tank, everything is set up for long distance travel.
The prior owner is a really nice guy and did good work to it. Got a great deal because the trans is toast and would cost $$$ in CA to get fixed.
@RUSH55
These are Trail Tailer’s pics on an FJ60. I’ll have to modify it some, but it will save a ton of grinding and cutting and headache from swapping over the stock 80 buckets and mounts.
it’s all time or money as I see it. This set up will save me enough time that it was worth the $. This will not be a 2-3 year project to get going.
I may just stay with Saginaw? It’s already in place:hmm: ive never used it before and not familiar with its issues, if any. I can tell you the 1/2 mile I’ve driven the truck that the PS is strong way better than the stock steering in my ‘69.
You are setting the bar high not only with your starting point but also with the dream build list and the SSS2020 goal! Awesome!!
