I haven't driven the cruiser for a while and now I am having some issues. Shame on me for not enjoying it more. I had driven it to Florida 2 years ago and parked it for a short time. I then drove it to VA and used it briefly to commute to DC. That was short lived so I drove it home to Maine and parked it until last weekend. It started right up and drives just fine. As I was going through my checklist before starting out in the cruiser I tested the diff lockers and they're not doing what I expect.
The issue that I am having is that the front and rear lockers won't engage. I did some searches and found a lot of information about taking them off, cleaning them, and being super careful about magnets in the motor. Before I start getting into it though I wanted to make sure that I am on the right path.
Here is what is happening.
1. Shifter in neutral, I can shift from high to neutral. Attempting to shift to low and I get a grinding sound. Shifting back to high I get the same sound.
2. In park I can shift from high to neutral, to low, without a problem.
NOTE- I thought shifting the transfer case into low occurred in neutral, not in park? I also thought the ABS light came on? It doesn't. I do end up in low though.
3. In park and low, if I turn the diff lock to RR, I get a flashing diff lock light.
4. In park and low, if I turn the diff lock to FFRR, I get two flashing lights.
I once again need to rely on my cruiser as I am back in Maine and it's winter. I hope my mud pals can help me out.
The threads I found below were helpful but I want to make sure what my diagnosis is before I try taking things apart.
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
How to fix a Locker - with Pictures
I am trying to attach pictures. I hope this works. Anyway, I have been having problems with my front locker getting stuck in the locked position for quite some time. In my opinion, it is worse if it gets stuck locked then if it doesn't engage at all. Anyway, my first call was to CDan...
forum.ih8mud.com
photos of e-locker actuator rebuild
forum.ih8mud.com
E Locker Actuator Rebuild Help
Hey Guys, I've been wiring up my rear 80series locker in my FJ40. It never worked, even after logic testing the wiring completely. The background of the build is a junkyard 80 series rear with homebrew wiring from reading multiple threads on here. So I followed a couple threads and decided to...
forum.ih8mud.com
Actuator Motor - Real Time Help Needed.
forum.ih8mud.com
Rear Locker Rebuild Kit? Guru?
forum.ih8mud.com
Slee - Fixing Diff Lock Actuator (Toyota 80 Series Land Cruiser)
Specialist in Toyota 80 Series Land Cruisers. Hard to find parts, off-road accessories and custom fabrication
www.sleeoffroad.com
Factory Locker Rebuild?
forum.ih8mud.com
I was asked to see what I might be able to do with a set of non working actuators. So I though I'd start a thread in hopes of helping others. Now these are really in a bad way and the outcome might not be what I'm hoping for but at least some of what I post might be useful. Being from New...
forum.ih8mud.com
rear e-locker actuator rebuild pics
Finally got around to doing this after putting it off for near two years. Like many, I had experienced the "sticky" actuator, tried "exercising" them, got it to work most times, sometimes just lived without it, etc. Last month it actually got stuck in the locked position with about 200 highway...
forum.ih8mud.com
Rear Locking Dif Assembly Help
forum.ih8mud.com
