Schumacher 180 Turbo Mig Welder
My buddy and I are going in together on a welder. Neither of us really have any experience or much knowledge on the subject. I will be using it for truck-related fabrication (bumpers, sliders, suspension bits) and my buddy is building a tube-chassis race car (think Ariel Atom). Anyhoo, it will be used mostly on thick steel and occasionally on sheet metal.
What specs should we be looking for from a welder? I do have 220v power in my garage.
Thanks in advance
This Schumacher MIG welder welds solid steel, aluminum or flux corded self-shielding steel wires. 230V, 60 Hz, single phase. Handles solid MIG (with shielding gas) or fluxed corded welding wires. Volts: 230, Amps: 180, Duty Cycle: 60% at 150 Amps
Mig Ready
Wire Feed Speed Control
Weldable Metals: Steel, aluminum, or flux corded selfshielding steel wires.
Clamp Cable Length (ft.): 10
Regulator and Gas Hose Included
Cart two rear wheels and two swivel casters
60 Hz, single phase CSA rated 8 heat settings 2-stage or 4-stage trigger control Four roll
Quick reset-style
Top-load wire feed syste
5ft. power cord (plug included)
Quick-connect MIG gun
Wire spool capacity: 4in.-12in. spools up to 30 lbs.
Built-in cart handles small to full-size cylinders.
Thanks in advance
