Is this the correct oil port for turboing?
Northern California
Website
www.facebook.com
I saw where someone had posted these plugs could be used for turboing as they were pressurized. Just want to confirm this one would work. Seems i could avoid the "T" issue at the senders.
Sorry, also need to verify what size line to run for the drain. Seems guys feel the pressure line should be 1/8" and the drain should be 1/2". I have to machine a drain adapter to attach to the turbo which has a 1/2" hole but a 1/2NPT is much larger than this opening. Would 1/4-18 or 3/8-18 NPT's be large enough as they are at or above the 1/2" drain hole? Thanks
You do NOT want to drain to a pressurized port. The port you have circled will do for oil supply as it is pressurized but use either a bung in the pan or the altenator/vacuum pump return for the oil return.
Your oil return should be a minimum of twice the diameter of the supply. You want the oil gone once it's made it's way through the turbo bearings.
If you've got A/C plans that port might get in the way of the A/C compressor or bracket too.
there is a similar port near the back of the engine (same side) that i have used int he past to turbo the 3B... that one will work as well...
Thanks Crushers. I remember a post about this somewhere. There is a raised galley along that side of block with about three of these plugs. This pic is of the forward plug. Will it make any difference(as in pressure) as to which i choose? And will i need to just use a 1/8" line straight to the turbo or does there need to be some restrictor put in? Thanks
you don't need to run a restrictor .. more oil, better.
the entire system should run at the same pressure so any one of the 3 of the plugs will work...
as Tapage states and oil restricor, if required, is built into the turbo. it is not oil pressure that you need to be concerned about it is oil volumm if you have more oil coming in than can gravity feed down then you will get oil pass the seals. 1/2" drain with no sharp 90s ABOVE the oil level in the pan and you are golden.
