Is this 80 series safe to drive even though there’s a ton of rust?
Northeast PA
Looks around the same as mine did when I decided to do something about it. I have a thread on here somewhere about what I did in detail (you can find it in mt profile).
In a nutshell I scraped all the rust I could get to, hit it with phosphoric acid, and then painted it with Sherwin Williams Macropoxy 646 which I salvaged from a construction job I was working on.
It's a crappy job, but 2 or 3 years later it still looks pretty good under there.
Check every inch of the steel brake lines. They will rust through and you'll lose half your brakes very quickly. Ask me how I know...
SmokingRocks
Don't tell my wife how much this actually cost...
Colorado
What is that some marine-grade anti-rust coating? gonna make servicing bushings, shocks, or anything that's bolted down tough.
jemsec
Mach lll Club
Moore Corner, AL (Irondale)
To repeat a previous comment: "Regrettably, Rust Never Gets better"!
Rossland BC
pressure wash it
dry it out in heated garage
spray every nook and cranny with Fluid Film.
check your brake lines/fuel lines/rear heater lines, they rust out the quickest and will leave you stranded or without brakes, fuel or coolant.
Northeast PA
It is literally a marine coating, Macropoxy 646.
Before I had rusty bolts that didn't come off. Not I have not rusty bolts that don't come off.
Colorado
It won't kill you, but I sure as hell wouldn't want to do any maintenance on it :hillbilly:
brooklyn, ny
Wow hahaha this is some industrial grade s*** never seen that before I’m assuming you lifted it to do all this right ?
Denver CO
You and @80 Series Al might hook up for beers:
Northeast PA
Wheel ramps, and a dropcloth. I pulled the body off the frame a few inches, but I also did all my body mounts at the same time.
N. Phx
Jesus wept. Does it roll in a straight line when driving down the road? Good luck, whatever you do,
ceylonfj40nut
Waiting for Barn Time
TX
Save some time. Beat the frame with a brass hammer like a wild banshee. Let the crumbs fall as much as they can. Then hit it with a needle scaler. This should get most of the loose stuff off.
Prince George BC
Go on partsouq and order new brake lines, all new hardware everywhere and then go get it sandblasted. You can then get a good quality coating of your choice on there. Be a great time to replace all the bushings, tie rods, shocks etc at the same time as well.
