Is these OME bushings are too worn (1 Viewer)
David*BJ70
Looking forward to reach the end of the world
Montréal, Canada
Last weekend, I had free time and 8 energy suspension poly bushing lying around. Without difficulty and 30 minutes later, I replace all the bushings of my rear shackles.
After cleaning up my old OME bushings, I wondered if they were, in fact, still quite good and reusable. They are not «dry» and as «soft» as a poly bushing can be.
It won't be very complicated to reinstall them but are they still good to believe that, even used, they a better alternative to my brand new Energy suspension poly bushings? Your opinion ?
I’d just do new ones. Unless bushings cost a lot more than I remember. Nothing worse than doing all the work to realize you need to do it all again.
If they're tight in the bushing hanger and the shackle pin isn't loose - they're fine. They look fine.
So let's create a poll ;)
Its all good. I see the logic in reusing them...and they are a lot easier to change than their OEM rubber counterparts.
OME bushings get brittle, for lack of a better word. Depending on how old, replace them.
I was doing the same thing when I realized all these old bushings were not going to last.
Think how many years it’s gonna be before you decide to go see again?
Go new.
I did not consider brittleness. Are ARB bushings not straight polyethylene? Poly is quite stable, except for eventual sun exposure issues.
Poly is quite stable in a neutral environment. But I've found that poly bushings in other cars wear out after a couple of years of use and degrade where the original factory rubber bushings last for decades without much wear.
