I don't have all my warning lights right now. I took the cluster out to check the bulbs. But, they don't have bulbs their all led. Could the led stop the warning lights from coming on?
94 w/ the 4.5lWarning lights do not create trouble codes. They may or may not alert you to certain issues the vehicles computer has recognized.
Since we don't know what year model your vehicle is (put it in your signature so we will know in the future) then we can't tell you HOW to access any trouble codes present. IF you have OBDII....just hook up a scanner and read any codes that are present or pending.
LED's in the cluster (not lighting) could be any number of things:
- The LED's are burned out
- The LED's are polarity sensitive and installed incorrectly
- The LED's are not the correct ones for use in the cluster (replace one with the correct bulb and holder and you'll have your answer)
- The cluster itself has a broken/inoperable circuit path
I was talking about the check engine light won't come on. I think that is the only way to pull the codes, am I right?94 w/ the 4.5l
94 w/ the 4.5l
Thanks for the infoCorrect. You will have to address that situation first.
It's the only way to 'read' the codes.
I see now what you were getting at.
