Is the Water pump Life only 60k on the 3UR-FE 5.7?
USA
I was reading this article here and it said the life of the water pump was approx 60,000 miles.
(Usually they get this information from a mean time to failure test report.)
Is the water pump a 60k maintenance item?
It said..
The 3UR-FE Engine Problems and Reliability
The 3UR-FE is the most reliable and durable engine for all UR engine family. The Toyota made over 1.3 million kilometers of durability testing for this engine. In reality, the 3UR-Fe can run more than 400,000 miles (650,000 km) smoothly with regular maintenance with using high-quality fuel and oil.
But nothing is perfect and this engine too. The 3UR-FE has a problem with coking of the piston oil rings which caused high oil consumption. After that, the oil consumption increases over time. To avoid this problem, use only the recommended high-quality oil and watch the oil level. The 3UR-FE crankcase ventilation system sensor fails hugely often, and electronic throttle system ETCS-i is not as reliable as it should be. The problem with water pump is also found in this engine. Like other UR engines, the 3UR-FE has a leaking water pump with short life about 60,000 miles (100,000 km).
Link is here:
It said..
Link is here:
That site is pure click bait - no legit organization is associated with that site. I wouldn't trust anything published on that site.
Clear as mud?
HTH
I've seen many weeping at 85-95k including my own fwiw. We sell more water pumps for 200's than 80 Series :eek:
Clear as mud?
HTH
You should definitely believe anything written in broken English.
"The 3UR-FE crankcase ventilation system sensor fails hugely often"
1929444
Don't forget to go to the bottom of their page and click on the hot link to their "Cookies Polisy" Then you can read their P-O-L-I-S-Y.
:banghead:
My Tundra water pump failed at 85k. I have a spare already for my 200.
It said..
Link is here:
My water pump crapped out at 69,000 miles on my 2015 LC
For whatever reason, when I bought my 08’ used with 48k miles on it…it had already had water pump replaced. 100k since then, no issues…but we’ll see. Also…re oil consumption mentioned in thread…mine is not consuming oil badly at all, even with hard, heavy, hot use.
