Im trying to troubleshoot a no start problem after rebuilding my engine, I want to clarify that the fuel pump should prime when the key is first turned on without actually cranking the engine. Looking at the fuel circuit in the manual, it looks like the circuit opening relay only activates when the ecu gets signal from the crank position sensor and a start signal from the starter. Judging by that the fuel pump will only run while the motor is cranking. Does that sound correct? I'm assuming it doesn't prime for a couple seconds when the ignition in first turned on and only while cranking. I don't recall ever having another vehicle with an electric fuel pump that didn't prime when you first turn ignition on, so I'd like for one of you guys that knows 80 series land cruisers to please verify if my thinking is correct.
I really appreciate any answers this simple problem is kicking my ass.
