is the fj55 front disk axle a direct bolt on
Discussion in '40- & 55-Series Tech' started by scubajohn, Feb 22, 2004.
  1. scubajohn
    scubajohn
    74
    Feb 6, 2004
    Is the fj55 front axle a direct bolt on to a 70 fj40 ? the PO added longer SS brake lines are the fittings to attach the disk brake calipers the same as the connection to a 1970 fj40.
    The axle is said to be in good condition and the calipers work but need pads. is 450 reasonable?
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,296
    Media:
    17
    Albums:
    1
    591
    Oct 1, 2003
    MN
    If it does not need anything else done to it, and it is ready to go, I would jump on it...
    Good luck!
    -Steve
  3. FJ55partsBoise
    FJ55partsBoise
    136
    Jun 8, 2003
    I agree with Steve. This is a good deal.
    I found a 1978 FJ55 front axle to bolt onto a 1974 landcruiser FJ40 front axle. I got the whole truck minus transfer case for $900 but I had to get rid of tons of parts. It sat in my garage for a month. Now that I think about it I would have preferred to spend the $450 for the disk axle only.
    $450 is about as cheap as it gets. Hopefully the disks are vented.
  4. notagp_afj55
    notagp_afj55
    867
    Jan 10, 2004
    Portland Oregon
    Hi
    just a side note. You wouldnt happen to have any wiring
    harness stuff left from that 55 would ya? I am struggling
    to find them good used
    thx a bunch
  5. FJ55partsBoise
    FJ55partsBoise
    136
    Jun 8, 2003
    Sorry the harness was a hack job. PO was building a rust free FJ55 and used the pieces he needed from the harness for his. There was very little left.
    If you want a 55 harness try Brian Hottel in Pocatello, ID (this is eastern Idaho, north of SLC, UT)
    here is his e-mail, hottel@dcdi.net.
    This guy has acres and acres of cruiser parts: 60, 55, 45, 40, 25 etc. Here is the down side, his prices seem to be sometimes a bit much.
  6. notagp_afj55
    notagp_afj55
    867
    Jan 10, 2004
    Portland Oregon
    Thanks very much
    I guess i can try and hope for the best
    Jim K
