Well i just bought my 80 about a month and have been accumulating parts since , Everything is a basic maintenance Execpt the Rear Pinion seal , which i think is just the vent but bought a seal just cause. So Tomorrow ill be Putting it under the knife for the day, Ill have a bay at my old place of employment and be able to use some nice machines. My list of things to do is
Full Tune up (plugs,wires,cap,rotor,fuel filter air filter)
All 3 belts and Idlers
Rear pinion seal
Trans Flush/filter (royal purple Atf)
Diffs/tcase fluid change (Mobil 1 syn 75-90)
Coolant Flush (Red Toyota)
Wipers f&r
I bought the prestone coolant kit I could use a BG machine for it but id rather flush it out completely and read good things about that here. For the trans Ill be using the BG machine which uses the Pumps pressure to flush it out. Ill do the Filter and pan gasket , then refill then do the flush, with royal purple being so much. All the Parts Are OEM Toyota except the wipers(rainex) and the Trans pan gasket (Napa) . Ill try to post some pics Tomorrow as I do everything.
Rear pinion seal
Wipers f&r
