Is it suppose to clank when.....
LOS ANGELES
Website
www.destechservices.com
Every time I put it in gear from neutral it clanks..... It's more noticable when the AC is on (higher rpms) Should I be worried? How can I fix?
Also when coasting down the HWY, If I release the throttle, it clanks and when I press, it thumps.
HELP I'm going camping with the Family and trailer 4th of July weekend....
Ahem... Pretty classic *1991-1992*.
It's normal.
And it won't affect your towing.
Not a noise, more like a "clunk". General consensus says it comes from the T-case, and the VC in later models supposedly cured it.
Most, if not all 91-92 owners (including myself), have reported a front end "clunk". I drove my buddy's 92 and another buddy's 91, both had the same clunk.
I was actually going to ask the same question at one point.
My 91 "clunks" when I put it into gear or switch from reverse to drive.
Cant find a thing wrong with it however and its always "clunked".
If there aren't any other symptoms of worn u-joints, probably not u-joints. If they were bad enough to be clunking like that, you would probably be hearing them or feeling vibration at other times.
I have a similar clunk when I shift into D from N or R on my '95 and it is clearly coming from somewhere up front, not the TC. It hasn't gotten worse in two years, and hasn't changed with new diff oil and u-joints. I remember reading something before about the drive flanges being a little worn and making this noise. I guess I'll see if that's it when I repack the front end this summer. Mine sounds like a big metal something falling onto another metal something. Just a quick, metallic engagement noise. Seems pretty benign.
Yep - it's "normal". When I first bought my truck, I ordered up a new set of OEM U-joints.... It clunked again within a few days and still clunks 12k miles later. Greasing the U-joints seems to help some, and going a little easier/smoother on the accelerator seems to help a little. It's a bit unnerving, but so many 91-92 owners have posted about it being "normal" that I've kinda learned to live with it.
