So, unlike most of my old vehicles, the heater works great in the fj60 (which btw the wife has named Hobbes), but the problem is that it doesn't ever stop working. It'll be 75 outside and inside it's 85. At first I attributed this to the GINORMOUS tranny hump producing radiant heat (which it does) but I just realized the other day that even when the blower is off and the temp is set to cold and the recirc is off (or on) there is a steady stream of hot air coming from the lower vents. Upon writing this I realize that the vents might be from the underdash AC system and that might be the issue; the belt to the AC unit is off. any suggestions? adjust the cable pulls to the air/heat system? if so, how and which way?
I know I took the lazy route and only did a half-assed search of the available forums but I thought, after slogging through endless posts about heater cores and inconsequential info, someone might hold the key to this.
