Ironman Foam Cell Pro Question
Grand Rapids, Mi.
I've done some looking around but can't find anything definitive. I just received the Stage 2 FCP kit and have a question.
For those of you running FCPs, are the D/S coils on the right side front and back? I can verify that the D/S rear coil is a bit taller, and would assume that's because of the gas tank being on the right AND that Aussies drive on the right side. I also bought the front struts pre-built, and they have D/S and N/S too, but are the same length. So...can I assume D/S coils go on the right/U.S. passenger side?
Any help is much appreciated!
Jay
This is always debated. I put the taller one on the passenger (gas tank) side when I had them. It had a bit of a lean at first (passenger side was high), but after a few thousand miles it seemed pretty level.
Ironman has supplemental instructions that state to put the DS on passenger side (I think the front only). Don't have access to the instructions anymore, but if you ask them for it they will send you the info.
