Eric Winkworth said:Standard thickness is 20mm
Minimum is 19mm
masteryota said:Are you getting just an add-a-leaf or the whole leaf pack?
I need the whole leaf pack myself..
Wondering where are you getting it?
you do not have to remove the leaf packs from the truck to install add-a-leafs...silvercrusher said:You need to make sure the new pins come in the kit. I've heard a few people say they didn't come with. If you are removing the spring you might want to replace the bushings or should i say you will have to replace after you burn them out. HAHA. While you are there you may as well put on a nice set of anti inversion shackles. Viola you are lifted.
I drove past your place on the way to the park the other day with my kid. Nice truck. Next time i'll stop and drink your beer.
Call if you need some help or tools you don't have . I may have what you need.
Cheers
Challis 743 -9983
crushers said:you do not have to remove the leaf packs from the truck to install add-a-leafs...
crushers said:too easy,
first dig install a cement pit in your garage
