Swbkrn2003
GOLD Star
I have seen a lot of threads on the forum and some are similar but i have not seen a solution.
I have an intermittent idle issue. Sometimes my 80 will idle fine (This happens hot or cold bu mostly after driving it for a while) It will idle perfectly at 650-700 and then after driving for a couple miles when I come to a stop it will idle around 1,000rpm or higher and if i put it in Neutral it will idle at either 1,400 or 1,200rpm. I turn off the A/C and then it will drop to 1,050 to 1,000-rpm. Now this is random sometimes it idels perfectly. I took it to my friends shop and used his Snapon Scanner and the IAC is working well and throttle responds to A/C on and off. Cleaned the Throttle Body and IAC. No apparent vacuum leaks.
It's driving me Bonkers. No Codes or CEL. I do not want to throw a ton a money if its something simple!? Thinking maybe PCV valve might be bad.
Open to any ideas and the great minds that exist on this forum and have years more experience than me!
Baffed in Paradise!
Baffed in Paradise!
