I have a new radiator on my lx450, and the engine temp stays at exactly half way and has toyota "Red" coolant in it , yet the water light goes on and off periodically ? Any ideas ? Thanks in advance !
Oil level light... ha?
ah well there you have it ! lol ... so it doesn't leak ... it must be burning it ...
it started coming on after my trail ride this weekend ...and after I saw the bear...
It may just be 'sticking'. Mine does that from time to time. I guess I need to pull it and clean it up. Usually, I just jerk the steering wheel (low speed) one direction to make the vehicle yaw....the oil splash in the oil pan will reset the sensor (its on an arm).
IF you know your oil level is good (check on level ground with oil dipstick), then just ignore it .....or pull it and clean it.
IF your oil is actually low, then you know what to do, right?
pull what and clean it ? oil sensor ? where would that be ?
