I'm getting an intermittent airbag light on my 2015 LC. I pulled codes, at the time the light was off (just got my code reader) and I had two historical codes related to the SRS system. B161A is "Lost Communication with Front Satellite Sensor Bus", and B1618 is "Front Airbag Sensor Left Initialization Incomplete" according to autocodes.com. Commonality between the two codes is the front left airbag sensor, and of course any wiring between that sensor and the computer/srs module, whoever those sensor answer to.
So I have a couple questions. I think I've Identified the sensor near the battery. If you know, is this pic airbag sensor? There is another one just like it on the passenger side of the engine compartment so I'm pretty sure that's the sensor but confirmation from someone who knows for sure would be nice.
How often do they go bad? I'm thinking first I will disconnect the battery and clean the connection, put a little grease on it. It is by the battery so corrosion my be an issue. Just curious if these things are known to go bad or if it's just a mechanical switch triggered by impact and should last forever. it looks like it might be rivited on so I'm not sure what all is necessary to change it if it turns out to be the problem.
Thanks
Rob
Thanks
Rob
