I found I had a bit of a wobble. Tires balanced, alignment is perfect, etc.
So I went hunting.
Guess what? Part #52392A (Diff support arm) is cracked clean in half! It has enough pressure on it to keep it in place, but it is allowing the diff to move and causing the vibration.
I was wondering why I saw a rub spot on the diff near the pinion and had loading/unloading noises as well as a vibration no matter what I did.
Go figure. Looks like I get to wrench a bit. Probably a good time to find it. The inner clamp on my PS CV let go too, probably because of the same problem.
So I went hunting.
