Interchangeability of these springy thingys.
ocala, Florida
Ok seeing how a 40 front spring has more flex and they have the same dimensions as a 40 rear is there any reason why a 40 front wont work in the rear? I know they will haul more weight and therefore i will pull the load leave from the pack when I swap the military wrap. Can any one see why they wouldnt work?
And which leaf or leaves should I pull?
A big reason for more flex is the weight over them is well matched to the spring rate. The rate of the front spring is probably 100lbs higher than the rear. I think if you put them in the rear it'll be stiff. Then again you're doing it so let us know what you think. Tim
Hi All:
Well, the front and rear springs are not the same, nor interchangable.
For one thing, the spring pins are in different locations.
Why do you think the front springs are more flexy than the rear springs?
Regards,
Alan
We measured the distance from the pin to the eyes on front and rear springs and the springs we had matched pretty close. Curious to see how many leaves have to come out for a acceptable ride and how long till they die. There is a wrap bar installed so hopefully the fatigue won't be quite as bad.
Ok the springs are in and they have the same measurements. I had to move nothing to get them in. I pulled the 2nd short leaf and swaped the wrap cuase I have my springs fliped for the longer wheel base. I will trail it in 2 weeks and let you know how they performed.
Hi All:
Regards,
Alan
Ok they do measure the same.
The spring pins are in the exact same location.
They flex better cuase they are thiner with more leaves to the pack.
