Commonly called the "Kick panel"....the fuses are mounted vertically above the “foot rest wedge”
Early years have fuses at the left kick panel, later years also behind the right hand side kick panel.
Well I check all mine, none of them look burn but still nothing on the dashCommonly called the "Kick panel".
Is that right?....
The instrument cluster fuse also powers the sub-fuel tank switch, the reversing lights, the alternator regulator and the instruments. I am not sure why the engine was cutting out but that problem righted itself once the problem was fixed.
How did you measure current at the fuse? When you say full battery voltage appears across it, that sounds like you did a voltage drop test across the fuse and read battery voltage, which would indicate an open fuse. Please clarify how you made this measurement as well.ALT-S, ALT and J/B No 2 fuses are ok.
I found (by measuring) that no current passes through the 7.5 A ALT-S fuse (to the alternator's field coil) - whether ignition is off, on, or engine running. The full battery voltage appears across it. So no wonder there is no alternator output.
Thanks, Don!How did you measure current at the fuse? When you say full battery voltage appears across it, that sounds like you did a voltage drop test across the fuse and read battery voltage, which would indicate an open fuse. Please clarify how you made this measurement as well.
You already know there is a wiring problem, so don't blame the alternator until you've fixed the root issue. Not sure if I mentioned this before, but I have had to replace an entire underhood fuse box for an intermittent engine stalling concern. It finally got bad enough that I could test for power in but no power out and, even then, it still felt like a roll of the dice to spend the coin for a new fuse box (just mentioning it as a possibility).
Thanks, again, Donal!
Yes, I managed to take out the fusebox. Green corrosion is mainly in the top left connector, and to a much lesser (and probably insignificant) extent in bottom left and the left middle/side connectors. To fix the top left connector, I will need to split open the fusebox, as at least one of the pins in that connector is almost detached. Trying to do open this module now; looks like several plastic rivets need to be broken in addition to unlatching clips/tabs along the sides of the clamshells.
I will write a separate post when I am done with this project.
Following website has the fusebox diagrams: Toyota Land Cruiser 100 (1998-2003) Fuse Diagram • FuseCheck.com - https://fusecheck.com/toyota/toyota-land-cruiser-100-1998-2003-fuse-diagram
Best Regards!
Someone posted about a short on their shifter I read in another post? But he stated if recall as soon as he put it into reverse the fuse would pop. Fixed the grounding in the reverse shifting area and it resolved itself. YmmvQuick update 2 hours after last post. 15 amp fuse will hold in garage idling revving loading the car up with all the light bars, flood lights, heater seat heaters. Even plugged the fridge in. Try to add as much load to the car as possible. 12.4 volts across battery terminals. Without a load the battery is charging at 13.8 volts. I can disconnect both negative and positive from the battery and the truck will continue to run. If I go into reverse that fuse pops immediately. Sitting in the garage idling everything is perfect! Attached is the charging wiring diagram I've been working off of. Upper right is the 15 amp gauge fuse that keeps blowing and killing the entire charging system. All other systems seem to be operable when the fuse goes except for the rear vents the mirror adjustment, and obviously all of the instrument cluster.
Any ideas please help.
