It seems a popular place to install the sender for the temp gauge is shown in the pic below(landcruiserphil). he also said the following about installing the ISSPRO temp gauge
The instructions of the gauge say "Install the sending unit" I don't know what size bits and want to make sure before I drill a hole in that neck.
Any tips on drilling and tapping would be appreciated. I have done plenty of drilling, but other than a few keg's, this will be my first tap.
LandCruiserPhil said:I installed a W/T sending unit the same place Dan speaks of a year ago. Depending on how anal you areyou dont need to remove anything. I used 2 cordless drills for the job (1 with the proper size bit, 1 with the tap) didnt even remove the radiator cap lost maybe 2 oz of coolant. Once you have everything together less then 1 minute to install the sensor. Drill, tap, and screw the sensor in = done.
