installing new weatherstrips (1 Viewer)
colorado
i tried to install new window weather strips on my 1987 fj 60 front doors.the new strips came with entirely new plastic clips with a flexible prong that must go in someplace but i don't know where? and the dealer can't tell me ! has anyone had this problem and can help me ?
thank you
richard marquart
ummm, which 'window' weather strips... ?
In-channel ?
outside of door-trim
inside of door-trim
the outside strips that go over the chrome trim moulding and against the window .
thanks for you quick response
I did this on the drivers door of my '87 60. At first it was kind of a brain teaser, but a friend who happened by looked at it and saw the solution. You move the clips that come with the piece(they slide back and forth) until they line up with the holes on the door. Then it just snaps in. Be careful not to bend the metal of the strip or it won't lie flat. I had to add a tiny bit of RTV to seal the front end 'cause I'd bent the strip in a slight "U" shape. Good Luck.
