Installing new rotors
Discussion in '80-Series Tech' started by 92Cruiser, Feb 27, 2004.
  1. 92Cruiser
    92Cruiser
    121
    Mar 28, 2003
    Ok, well I know its been brought up many times but I couldnt find anything in the search. I've got new OEM rotors and pads for the 92. I'm wondering what the correct procedure is for installation. I've heard things like having to turn the rotors after they are attached to the hub because they warp when being bolted on. Also what tools will be needed for sure. I've never done rotors or pads in the past so I'm not really sure what to expect. I do have the FSM but any help would be great.
    Thank you,
    Brian
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    21,983
    5,763
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    New OEM rotors do not require turning after installation. Do be sure to torque them to spec, WITHOUT AIR TOOLS, in a cross pattern. They will not warp using this method. Do be sure to clean the friction surfaces with a suitable de-greaser before installation.
    D-
  3. Beowulf
    Beowulf
    12,529
    54
    Mar 27, 2003
    Somewhere in the foothills...
    Brian,
    Here is an old post but the procedure hasn't changed.
    -B-
  4. Landpimp
    Landpimp GOLD Star
    15,873
    Media:
    1
    1,913
    Mar 14, 2003
    Gig Harbor WA
    Dan, am I correct that Toyota stores its rotors a certain way(flat? not on end) so they don't warp when sitting on the shelf? (I recall hearing this) I know most aftermarket rotors really should be lightly turned before install and must be turned attached to the hub.
    [quote author=cruiserdan link=board=2;threadid=12218;start=msg112091#msg112091 date=1077946837]
    D-
    [/quote]
  5. IdahoDoug
    IdahoDoug
    8,848
    248
    Aug 9, 2003
    Pimp,
    Sounds like an old wives tale, though I cannot imagine old wives discussing brake rotors and such. If a rotor (aftermarket or no) comes from the factory properly machined flat, I cannot imagine why it would need to be touched up once correctly mounted.
  6. Landpimp
    Landpimp GOLD Star
    15,873
    Media:
    1
    1,913
    Mar 14, 2003
    Gig Harbor WA
    thats what I was thinking. But doesn't it make "some" sense that if the rotor is stored at an angle....that it could slightly warp just from sitting funny on the shelf?
    the local brake shop turns all new rotors, no charge.
    that said I have installed a pile of rotors, only turned a few when new
    [quote author=IdahoDoug link=board=2;threadid=12218;start=msg112328#msg112328 date=1077997406]
    Pimp,
    [/quote]
  7. cruiserdan
    21,983
    5,763
    Mar 27, 2003
    Pimp,
    Storage is not the issue, you should see the animals that transport them sometimes :eek: Do you remember the old Samsonite commercial with the Gorilla and the suitcase?
  8. Landpimp
    Landpimp GOLD Star
    15,873
    Media:
    1
    1,913
    Mar 14, 2003
    Gig Harbor WA
    so my parts don't ride on a red velvet pillow? :flipoff2:
    [quote author=cruiserdan link=board=2;threadid=12218;start=msg112404#msg112404 date=1078012464]
    Pimp,
    [/quote]
