Last weekend I installed the Lutz Auto Speedometer Correction device on my 06 LC100. My rig has Rock Warriors with 285/70/17's so slightly taller than the stock tire size. It was a one
job and took < 1 hour hour including a few freeway runs to make sure it was accurate.
This is what I purchased: Toyota 3 Wire Speed Sensor Calibrator/Correction Device | Lutz Auto The cost was $114.95
The attached directions were very easy; you first determine the speedo error as a % by dividing actual speed over the indictated speed, minus 1. So, for me it was 73/70 - 1 = .0429 so I round up to 4.5%. Once you install the unit in-line at the transfer case wiring harness (key in on position) you simple push either the up or down button to correct your speedometer. Each push is .5%, so again, in my case I pushed the up arrow button 9 times (4.5 x 2). Done.
I took a test drive to ensure accuracy then per their directions I ran a bead of RTV to seal the box and zip tied it above the wiring for the transfer case. Works perfect; its accurate and and there is no lag or anything different from the way my speedometer operated without this in place.
My only small complaint is that I wish the unit had a rubber weather sleeve to better shield/protect the connectors. I suppose it would be easy to tape or wrap the connectors which I may end up doing.
Nick
View attachment 2399479View attachment 2399479
job and took < 1 hour hour including a few freeway runs to make sure it was accurate.This is what I purchased: Toyota 3 Wire Speed Sensor Calibrator/Correction Device | Lutz Auto The cost was $114.95
Nick
