Installing ARB compressor - Best location for accessory & dash illumination tap?
that's a 'key on' item
Ahhh.....you are correct and the more I thought about it, that more acurately describes what I was looking for. Something that would only power up when the truck was in the ON position. My apologies for the earlier post where I had not thought it through completely.
Ah. What I tapped works both when in ACC mode as well as ON.
Pretty sure the Air Conditioning only works when the vehicle is on, not when in ACC only. So you might try to check that. I have a feeling though that what you’re seeing is that all circuits may be powered even in ACC mode but there’s likely a relay or ECU that prevents them from turning on. Will have to look through the FSM wiring diagrams to confirm
