Installing an aftermarket water temp guage
Discussion in 'Diesel Tech / 24 volts' started by cruisermantis, Jul 18, 2005.
  1. cruisermantis
    cruisermantis
    52
    Apr 4, 2004
    Kansas City
    I'm installing an aftermarket water temp guage in an '85 BJ70, and need to know if I'll need an adapter? Are the ports on the thermostat housing NPT?
    Also, I notice there are three ports on the T-stat housing. The rearmost two are utilized. The front one is not. It's looks like about a 1/2" port, and is just below the top water hose (U.S. Drivers side of vehicle). Any reason not to utilize this port for this purpose?
    Thanks
    Reid
  2. fjbj40
    fjbj40
    1,126
    25
    Jun 26, 2004
    east coast Canada
    the port you are talking about , on the thermostat housing , is the one i used for my aftermarket mechanical temp gauge and it works just fine . you may have to do some grinding on the inside if the probe is to long , I had to , but it is a good spot. I put in an equis gauge (s) , water temp , volt and oil px. that I got from Walmart . $50.00 and came with all necessary adapters and back lighting. If I knew how to post pics I would .
    hth , Daryl
  3. crushers
    crushers post ho
    22,189
    206
    Feb 10, 2004
    Tara Ontario
    works fine, i have used that port as well...
    cheers
  4. cruisermantis
    cruisermantis
    52
    Apr 4, 2004
    Kansas City
    Thanks, guys. I'll probably plan on that. Hopefully I won't have to remove material from the housing. So does anyone recall if it's NPT? Also, am I safe to assume that any contact between the probe and the metal of the t-stat housing would be unacceptable and give skewed readings?
    Thanks
    Reid
