The clip on the door handle is much easier to get off if you get rid of that plastic wheel between the handle and the door, and make sure to put the clip back on the correct side... theres a tab that holds it out a bit to make it easier for removal next time.
For the plastic sheet instead of pulling it completely off you can just slit it open where you need to get through it (at the bolt locations), and maybe slice a tab open at the bottom acces hole. Then just tape those holes back up.
