Installed OME/HFS suspension 2.5" today....shock hardware and goofy angles?
It took me and Cruiser_007 a while to cram those HFS springs into the front/rear hangers; we ended up using a spare inner front axle fit into the rear hanger cutout to bend the mount outward to accommodate new bushings and spring width. Part "A" below:
http://us.st11.yimg.com/us.st.yimg.com/I/coolfj40_1982_8434762
Made great progress, front axle is now mounted and the openings are ground to accept fine spline birfs. Rear inners are still getting cleaned up to a lovely shine before I install them and the rear discs, though rear axle housing is maneuvered in to the ready position. OME shocks were hung but the hardware included was basically nonexistent, so I need to order some front pins, castellated nuts and the bushing cups since all the old was thrashed. As the build proceeded the passenger's frame rail was conspicuously cambered negatively, causing the front shock on that side to miss the shock tower completely. Wonder what to do about that? Wonder what happened? Chris suggested ratcheting the rails tight up front and repairing the broken weld on the inner tab inside that rail to square everything back up. We had a funky platform bumper bolted up to the rails for carrying deer & necessitated removal of the front gussets on top and sides when the 40 was down at the ranch in Eagle Pass. I chunked it. Frame measurement up front is 724mm, a few mm short o' factory specs.
Tomorrow install inners, seals, birfs, clips, knuckles, rotors, rebuild & install/calipers, rebuild & install Aisin lockouts, call my mech to get the rear inners & order lines/etc from Summit. I'm whipped. My wallet is losing weight rapidly.
FYI, yes, the $90k Benz stays outside and the Cruiser is in the garage. Funny how that is. My X5 is on the damn street. No room where we live.
BTW who carries shock hardware and what should I do about the passenger side? Gonna check Summit, etc.
Thanks Poser for your guidance......here's the pics:
....notice that left shackle pointing at the ground?
Best of all, I picked up that rear axle like a barbell not realizing its weight in that position and DAMN! I had to curl it, cradle it, or drop it. I elected to curl and cradle. Big mistake. Both wrists went, "Pop!" and I set it on those sturdy boxes. Whew. I half expected my lower vertebrae to go exploding out my back and richochet off the garage walls like a hockey puck. Apart from feeling like a fought a cagefight last night, all is well. I'm lucky.
