Can a 'short shifter' be installed on a 1973 fj40? If so, what brand?
Has anyone bent the shifter so it doesn’t make you cross your legs when shifting a 4 speed into reverse? Hopefully it won’t be as bad once I modify the seat back two more inches.
Yes, several times. Propane torch to warm it up, bench vice to make slow, controlled bends. Very happy with the results.Has anyone bent the shifter so it doesn’t make you cross your legs when shifting a 4 speed into reverse? Hopefully it won’t be as bad once I modify the seat back two more inches.
