I found a loose main bearing shim after crankshaft removal, one of about a half dozen installed by the Factory in several locations on this 1971 "F" block. Does anyone have the factory specs for the inside diameter between the main caps and the corresponding bearing recesses? My experience with shimmed caps is nonexistent. If I chew up any bearings in this rebuild I'll need to jump in the river with it chained to my leg.
