inner axle? (1 Viewer)
Walnut Creek, CA
My 75 fj40 has a mini truck conversion by the previous owner. Which inner axle is typically used the mini or the FJ40? Are they the same lengths? Just curious. I should have measured them when I had everything a part :doh:
if you have a cruiser front axle with a minitruck disc conversion, the inner axles are still the FJ40 length.
Yup, Woodys the man.... ;)
Any disc/drum FJ40 axle will have the same inner axles (assuming 30 spl. at the diff)... regardless of the dic conversion uses (assuming Toyota parts used)
[quote author=toygeek link=board=1;threadid=9027;start=msg78481#msg78481 date=1071971885]
...The mini inners are about 1" longer. ...[/quote]
Negative...
The mini long side is ~2.5" longer than the 40/45 and the short side is ~1" shorter than the 40/45.
:D
