Hello fellow diesel friends.
I recently started having a strange issue with my 1HD engine in my 1992 HDJ81. A little back story. I have owned this rig for just over a year. About 6 months ago, I started having fuel issues. In part of my diagnostics, I removed the ACSD (sp?) device, and found it to be broken. The tab had broken off of the shaft. So, I bought a block off plate, and got rid of the device. Everything was good. I also replaced the primer pump/fuel filter housing. Which solved my fuel starvation issues. Fast forward to about 2 months ago, the first time the temps dropped below 50 degrees outside, and my engine started doing some weird things. It would idle really low, and die at stop lights, and sometimes when I was slowing down and the transmission would downshift. I got pretty good at shifting into neutral and restarting the engine. Well, now it is really bad, and it dies all the time. So, a couple weeks ago, I thought I would be smart and do a basic injector pump setup. I pulled the boost compensator off the top of the pump, pulled out the pin, made a grindy mod to the pin so I could easily put it back in (thank you webs), and proceeded to spin the star wheel, adjust the fuel pin angle, and then tweak all the other things. However, now it is worse than ever. It won't idle at anything below 1000rpm, it hunts at idle, and still dies if I slow down really fast to a stop. And, it has way less power then it used to.
Basically, I don't know what I'm doing. I don't know how to tune this Injector Pump. I have read a lot about how to adjust/tune these things, but there are so many contradicting methods, that I don't know what to believe. I don't know where to start. Where should the star wheel be? From the top, or from the bottom? I don't know. Where is the best position for the fuel pin? I don't know. Maybe my pump is just damaged from the ACSD being broken, and metal chunks got in the pump and caused wear? I don't know. What I would like, is to learn how to start from scratch, do a basic baseline adjustment on this thing. I would love to get the idle back down to 850, and get it to catch the idle when I let off the pedal. Right now, when I let off the gas pedal, I have to give it a little rev before it hits bottom, otherwise it will die. I am SOOO frustrated right now.
If anyone can give me some insight, I would be very thankful. I am planning on pulling the pump and sending it out to get rebuilt soon, as soon as I get my fresh pump back from the diesel shop for my Corolla and can get that thing back on the road again. But yeah, if any of this makes sense to anyone, and can give me some starting points, I would really appreciate it!!
Thank y'all for listening to my rant, and I hope someone out there can give me some guidance. Merry Christmas to all of you, I hope you all have a wonderful time with family. I am very blessed to be a part of this impressive community.
-Eric Mollerstuen
-Eric Mollerstuen
