Need a little input for my brothers BJ40. He rolled it twice into a river (totally underwater) about a month ago and there begins the problem. He took it to a mechanic to have all the fluid using systems flushed and changed including the fuel system. After this was done, the truck smoked (white) a lot so the mechanic recommended replacing the injector points. They were calibrated and replaced. Now when you start it, you still get LOTS and I mean LOTS of white smoke. Looks like the mosquito truck and now has a really bad knock. When you crack the injector lines with it running all are getting fuel and the knock gets a little less noisy (but not much). I personally think the injectors arent calibrated or not set correctly and it is getting too much fuel, but was looking for some direction if I am way off track.
BTW, the mechanics suck here, every single one of them and if it were my truck I probably would kick this mechanics ass for some of the things that he said he did but didnt. EX: "I flushed the fuel system" ok, so why didnt you even open the fuel filter and pour out the pint of river water that was still in it? Numerous other things....sorry.....short vent over. Pura vida.
Just enough to cause poor combustion in one cylinder . This also causes white smoke. If you do a compression check you will figure out if thats your problem or not.
