Dozer18
Fellas,
Been going through some overheating/leaking problems but getting it worked out. Want to run something by you guys to make sure I'm not going crazy. Recently replaced my water pump, and while I was at it replaced the belts, hoses, and coolant temp sensor. After burping the system, etc, it's running hot -- about 80% of the way up the gauge towards the red.
So today I take an infrared thermo and hold it on the T-stat housing, while running, at normal operating temp. I watched while the temp showed 207, then the t-stat opened and it dropped to about 187. Held for a few seconds, t-stat closed, and it rose again until the t-stat opened. Never got higher than 207-208.
You guys think I got a bad sensor from CCOT? Hate to use the name, but I've read a few posts from others implying the same thing. Am I missing something in the temp readings? Any advice is much appreciated. Have a great weekend!
Dozer
Dozer
